forgot to say that I am in Melbourne, and plz suggest some websites to buy from, thanks
Hi Guys,
Yesterday I bought a 1996 Golf CL 1.8, the car has done 90K only but needs some repairs and a new clutch...
First thing that I noticed is that the engine is sooo weak for a 1.8 engine, may be because its only 89 hp with a damaged clutch..,
Anyways, I will fix all of that, but I want to get some performance parts like the spark plugs, coils, air filter, may be bigger injectors...just light tuning, u know... coz I got no cash ... so what and where to get these stuff from???
K&N doesn't have performance filters for this model...
What do you think of the NGK iridium, I have read that it adds 10 hp
Coils, Splitfire? NGK?... Advice ;p
Injectors, Bosch I guess will do, may be I can get those of the 2.0 engine
Thanks in advance boys...
hey welcome to the forum, congrats on the car too, you've come to the right place.
For spark plugs, I doubt it doesn't anything much, if you have the money to splash on them go ahead. I couldn't feel any difference after I had them in.
I had in mind CL and GL have same air box, some one please confirm.
I am sure our melb memeber would be delighted help you with shop locatiions. JUst wait.
Hi
Fix the clutch first and release the mighty power of the 1.8
I can mail order you a clutch for $350 if you cant get one locally. 0423 051737 Camden GTI
The reason the 1.8s feel sluggish is the single injector setup that looks like a carby. You cant change the injector and the 2L has 4 of em, not one.
Filter should be the same as GL Golf, but if not, its the same as a SEAT Cordoba.
The only tuning that will make much difference is a CAM. Try a Mk2 GTI one.
Enjoy the car and revel in your wind up windows which will never break.
Welcome to the forums Mars3v Do you have a 3-door model?
Also, in reply to your K&N air filters, they DO make a replacement panel filter for your model. All the airboxes are the same size across the Mk3 models. The part number for the K&N panel air filter is 33-2069. You can also mod your stock air box to draw more air in. Check out the DIY sticky on the Mk3 forum
Welcome mate... Iv got a 1.8 and they are a bit lack luster but are an awsome base... Get the brakes and suspension set up and then go crazy under the bonnet
Thanks alot guys for this warm welcome, it touched my heart, really it did
Soundofav6, I found u the website that said that NGK irridiums add 10 HP, I don't beleive it as well, have a look anyway;
http://www.yourhotcar.com/product/li...ts/Spark_Plugs
you can also enter your car's model and year and it will show all the performance parts and accessories available for you beast.
Golf Loon, Thanks, I will fix the clutch, but what mighty power are u talkin about ...I will get back to you if I couldn't find the clutch, thanks very much.
rayray086, No I have the 5 doors one, thanks for your effort but I guess I wasn't clear enough, I want a high performance filter like the Typhoon series from K&N or cold intakes with the heat shield, but replacement filters won't do much...I checked the DIY topic, really perfect, thanks.
Water Boy I will go crazy under the bonnet, don't u worry
Guys, any idea how much a 2.0 16V engine would cost? I think its code is APF (not sure)... its 148 HP,after the mods it should be really powerful.. in my opinion, its better than the VR6 where I need to live near by a petrol station
ABF 2L 16v. Theny you need the loom and ecu and to dismantle your car and reassemble. Brobably $2500 plus labour. There were only 75 ABFs evevr sold in Oz, so good luck.
what type of economy does the 1.8 8v get anyway? the vr6 gets 13-ish surely its worth it?
2x Caddy, 1x Ducato
mine gets 9-ish if I dordle and 11-ish if I start smacking it. Dunno what you're all on about
