That wont come with the mounts and bearings, although you could get them pretty cheaply from here MK3 VR6 Front upper strut mounts and bearings (set of 2) - $59.95 : Dub Ad·dic·tion [duhb uh-dik-shuhn]
Chances are the old ones are already shot from being quite old, or soon will be when you change to a much stiffer suspension. I don't think you have to change them when you put coilovers in (I didn't, but then realised later that I actually had too, so had to take the fronts out, get new mounts and put them back in again) but it is recommended.
EDIT: ray explains it better in next post, haha
- You may not post replies
- You may not edit your posts
Forum Rules
