Results 1 to 10 of 11
Thread: JOM Coilovers
    Aug 2012
    Kangaroo Valley, NSW
    JOM Coilovers
    Has anyone had experience with these coilovers on a golf, i have found reviews they are very mixed but mostly positive this was on an Audi forum.
    Anywho it'd lovely to find out about them.
    Cheers.
    Aug 2009
    ACT
    If you want a cheap and bumpy, but low ride, they're fine. If you're after something remotely comfortable, get weitecs, or KW's or something.
    Jun 2012
    wollongong
    They are very stiff coilovers, mate's mk1 golf took about 3 months for them to settle and wear in, the ride is actually alright now. But I agree with ffoff kw's or weitecs for comfort.
    Something new
    Aug 2006
    Melbourne VIC
    Budget coilovers that get you LOW.
    Aug 2012
    Quote Originally Posted by Water Boy View Post
    I like everything about this statement.
    Jun 2011
    I think, the lower scale Coilovers are essentially the same.
    I have tuning arts. I'm about 10mm from as low as they will go and with stretch the ride is more comfortable then my pops AU tickford.
    There perfectly livable. Not really bouncy to much.
    For performance, the rear is a bit to soft. But the front is perfect.
    Aug 2012
    Positive i like it, i might just invest in these per say.
    Jun 2011
    For only $500 they'll get you scene low. If you want low and comfort you'll want something damper adjustable.
    Apr 2012
    Milperra, N.S.W
    JOM do a set with adjustable dampening:
    eBay Australia: Buy new & used fashion, electronics & home d
    I was considering these. Sorta priced between the cheap ones From JOM and the intermediate ones like Weitecs.
    '95 Golf 3dr... low. slow. loud.
    Nov 2010
    sunshine,vic
    I had them for 2 years and still do
    they're good and soft if your 100mm from lowest point but once you get close to the bump stops it gets bouncy
    good on corners abit soft at the rear end. Ive had annoying rubber noises on the front that i could figure out and found out it was the dust boots just needed abit of silicone spray and they shut up
    94' Golf Mk3 Vr6
