Results 1 to 6 of 6
Thread: jacking up a mk 3 - advice
    Oct 2005
    sharing some experience with problems jacking up a mk3
    started with a simple tyre change using the supplied cantilevered arm jack (the type that is like half a scissors type jack). the thing has to extend sooo high that the jack moved out of vertical and the bracket that engages with the car (a bent piece of metal forming a slot) actually bent open to far - and guess what - the car slipped off the jack!. and bent the sill on the car where the jack mounts
    took it to the dealer and he replicated the problem and replaced the skirting.
    this jack one of the worst things vw ever came up with. why not go with a proper cut or cast metal mounting bracket to prevent deformation and better still a convetional scissors type jack that you can find in any japanese car that is always going to go straight up?
    advice is to use a trolley jack (but you have to go further inside the car to reach its suggested reinforced jacking points)
    \'95 Golf VR6
    imported_brackie Guest
    Not good enough!
    Can't believe that VAG would stuff up so majorly. Suggest a trip to the wreckers and find a jack form another make of car that will do the job that you want. Can't really carry a trolley jack around with you!
    Oct 2005
    yep that is another good option
    i tried a honda scissors jack but you need to do a bit of cutting and welding to make the mounting slot wide enough and tall enough to get the same effect.
    \'95 Golf VR6
    Point Cook, Vic
    ahh the ol widow maker. Be careful with that thing u hear!
    Must be a german thing. Old school BMWs come with a similar thing too.
    Camden, Sydney
    A lot of Mk3s had the Jack recalled as they were dangerous. Use an Audi, or earlier Golf scissor one, or Toyota are good and cheap.
    syncro Guest
    Quote Originally Posted by Golf Loon
    A lot of Mk3s had the Jack recalled .
    The recall was for the sticker.........
Similar Threads
  1. Mk1 Brakes...advice plse
    By gmhendo in forum Diesels
    Last Post: 04-02-2007, 04:20 PM
  2. Bottom End rebuild Advice
    By smithy010 in forum Mk1 Golf
    Last Post: 28-10-2006, 11:13 AM
  3. Advice on 16v head
    By static1800 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 11-05-2006, 10:56 PM
  4. 1974 Passat Advice
    By vinderliker in forum Passat (B1, B2 & B3)
    Last Post: 06-03-2006, 10:46 AM
  5. Need advice on what to buy
    By worm in forum Mk1 Golf
    Last Post: 15-12-2005, 11:23 PM
