Welcome beancounter!!!
Congrats on your purchase, you're right it's a great breed. I came over from the dark side (an XRto my GL, and have had a ball. My little baby (Bjelo is her name-o) started out life a little rough, as she had a lot of hidden problems. Most of them surprisingly similar to what you are describing...
First things first - VW at the time designed the motors under certain circumstances to run up to 15,000kms without an oil change. It's not advisable, but if the oil was topped up as properly, there should be minimal gumming of the oil, and should be able to be rectified by doing what i did -
I first removed the existing oil, but left the oil filter in place. I replaced the oil with $10 Gulf-Western garbage, put in a bottle of oil flush, and drove up and down the highway for 45 minutes. I put the car straight up on the blocks and dumped the oil with the engine steaming hot, and ditched the filter as well. Replaced filter and oil with premium products, and while the car was off it's feet, dumped the coolant, flushed the system, and replaced it. Use the new G12 Plus from VW.
Secondly, the car ran ok, but felt a little breathless under 2K. Injectors had been clogged by crap fuel and the plugs were black as sin. I ran a whole big bottle of Lucas Fuel Conditioner through the tank over my first several tanks (in Shell V-Power of course) and have only ever run V-Power. Made a huge difference. At the same time i pulled off the pipe from the airbox to the throttle body, pulled the body off and cleaned it thoroughly and CAREFULLY, as well as replacing the dreadfully dirty and clogged air filter element with a K&N (I modified the airbox as well, but be prepared for increased induction noise).
My reverse gear has been screaming at me since day dot. Pretty sure the G'box is R@@TED, but then it is an 02O box which is different to yours. Knocking on wood now, but it's still going hard, and i don't baby it. I did dump the original gear oil and replace it with Penrite SIN with a Lucas treatment in it, and it has quietened things down a lot...
I really hope this helps you a bit. I'm no mechanic, but i love my dub, and this site. Welcome, and i hope you enjoy being a part of the 'coolers
Cheers!!!
JHN
