No going on Saturday for it, I just already got a quote for itOriginally Posted by 1DUB2C
A rear box is the end of the exhaust what some people call the back box its the metal casing with the two pipes sticking out the end of the car at the back.
Coilovers will do this they are the springs and shock absorber in one, they can be adjusted within the engine bay. It will be a much more bumpier ride but you will be able to take corners without problems![]()
Welcome D.I.T
Any pictures of the beast (VR6) ???
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
So this is a seperate part needed when i change the exhaust? What brand do you guys recommend for both exhaust and rear box?
Sound like exactly what i want then. Also what brands are you guys using? Also $$ involved?
If all goes will will have pics up mid next week.
PS. i would also like to add you guys are a top bunch of blokes thanks heaps already for all you patients with silly questions and advice
Coil overs are hight adjustible. compresion and rebound adjustible.
Using coilovers, you completly replace your front struts, and rear shocks. The coil over has a threaded section on the shock body, allowing you to wing the spring up and down the shock, raising and lowering the car. This also has the effect of Changing the tension on the spring (slightly) and altering static sag (ride hight)
Mate to answer your questions there are alot but I will try. Shop Around for your exhaust, as you can get different types it depends really what you want. Prefereably I'd go for the twin tip ones "ITS NIICE" (thanks Borat)
Look at Ebay you can get magnex ones that are a couple hundred dollars not that much when Remus costs $480 for the rear box.
Coilovers well for the KW+2's I got quoted $1900 from Seb(BugRacer) I think not sure but hes in Sydney.
Not sure you would have to ask Seb as he sells it himself.
We are a pretty bunch of dub lovers we are good to have another vr6 on board I'd say![]()
1) Could i get lowered without coilovers? what pros cons? my standard i mean done by pedders etc...
2) If i get a good quality exhaust do i still need to get a rear box? i used to work for Red Back exhausts so i can get a top one pretty cheap.
3) Where can i get the air intake upgrade? can i do it myself or do i need to take it somewhere to get it done.
ALSO guys, i need a steering wheel for the car the old one is a bit ratty and i want to replace it. Can anybody help here or recommend where i can find one?
Welcom good to see another Victorian on the crew...
Mate for suspension some places to check out in Melbourne are Toper Performance in Trade Place Vermont (Near Ethridge) and Center Line suspension over th other side of town both are really good and happy to give advice...
Cheers James![]()
The 2 most common ways people lower their VR6s are:
1. Install coilovers. KW Variant 2 @ $1900 from Seb would be you best option for balance of cost, quality and ride.
2. Install sports dampers (shock adsorbers) with lowered sports springs. The most common combination is Koni yellow dampers (rebound adjustable) with Eibach springs. This setup will cost around $1500 but could be done cheaper if you can find the right supplier overseas. A budget solution (that still gives a reasonable ride) might be KYB Excel-G dampers (I had these before my Koni's, nothing wrong with them just no rebound adjustment) with Lovell or King springs. You can put lowered springs in with the standard dampers, but you will drastically reduce their life as they are not designed for the shortened stroke.
Do a bit of net-research about suspension generally to familiarise yourself with what options you have.
Regarding exhaust. Look under your car. You will see a pipe coming down from the engine that goes into the catalytic converter near the front of the car. A pipe from this goes to the back of the car, and joins the enormous muffler that sits under the rear seats (often called the "suitcase" as its about as big as one). A pipe from this muffler goes to the back of the car to the rear muffler/back box/rear box/whatever-you-want-to-call-it. Mufflers are used in the exhaust system to muffle the noise such that you don't get ruptured kidneys, however another effect is that they restrict exhaust flow. Many people remove the "suitcase" to free-up the exhaust, resulting in more top-end power, but also a lot more noise intrusion into the cabin. If you were to do this I would recommend getting a quality rear muffler. A cheap rear muffler will drone and drive you mad in no time.
Again, do a bit of research about what an exhaust system does and how it works. Mufflers, in my opinion, are very much a "you get what you paid for" type of item. Use a quality, high-flow rear muffler, a resonator/hotdog in place of the suitcase, and all piping custom made by your local exhaust shop (best bang for bucks).
Regarding your intake, I think most intake systems are not worth the money. Your best choice, IMHO, is to get a K&N filter element (~$120) for your standard box and fit some kind of cold air conduit as the factory one is restricted and pulls air from inside the front quarter panel. As it turns out, I have a spare K&N element and I'm in Melbourne![]()
Regards your steering wheel question, I suggest putting up with it unless you are willing to risk having an unroadworthy car. The factory one has an airbag while aftermarket steering wheels that you might find on ebay or at Autobarn do not. Since the car had an airbag from factory, it requires it to meet road worthiness. Also, without the airbag the airbag dash light will flash all the time. You would need to remove the instrument cluster and remove the globe. The only option that might be OK would be a factory MKIV Golf GTI wheel, but finding one for sale would be a bit tough....
Enjoy learning more about your car !
