Results 1 to 8 of 8
Thread: Intermittent VR ...
Golf Houso Intermittent VR ... 06-11-2008, 07:57 PM
h100vw I used to fit alarms and... 06-11-2008, 08:07 PM
Golf Houso That might explain why the... 06-11-2008, 08:49 PM
Jmac The humming noise is your... 06-11-2008, 11:55 PM
Golf Houso thanks for that I was worried... 07-11-2008, 09:33 AM
Mrk_Mickey Shotgun that manual every now... 07-11-2008, 05:20 PM
Golf Houso Nah not really, just stay out... 07-11-2008, 07:28 PM
Golf Houso Well... I think I found it.... 11-11-2008, 05:47 PM
    Jan 2007
    I used to fit alarms and stuff. I would expect the immobiliser to cut the fuel pump and the starter motor. The normal place to get these would be under the steering column for the starter. The fat red/black is the wire, you'll probably find it's got some black wires connected to it and these will run off to the immobiliser, wherever it is. From there you'll be able to hunt down the fuel pump cut. I used to do this in the drivers side sill. The wire is yellow and red IIRC.
    It sounds to me like you have a relay problem.
    That might explain why the low steering column trim isn't properly in-place, I'll definately have a look at that in the next few days.
    Aug 2007
    The humming noise is your auxillary water pump by the sounds mate and they are meant to run after shut down.
    Alba European
    Jan 2007
    Quote Originally Posted by Jmac View Post
    thanks for that I was worried for a minute about that, its completely different to the GL too. I've got the Bentley manual on the way too so that should help me learn more about the VR6 motor.
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by Golf Houso View Post
    Shotgun that manual every now and then
    I should come check your car out soon mate...are there many big speedbumps in your area? *hides*
    Jan 2007
    Quote Originally Posted by Mrk_Mickey View Post
    Nah not really, just stay out of the left lane to avoid the manholes, you should be ok
    Jan 2007
    Well... I think I found it. The green/red wires snake up and into the steering wheel, how would I go about disconnecting the system properly?
