![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
interesting indicators
Today i tried to put in the clear front indicators of a 94 VR6 into my 96 GL and noticed that it can't really be done with a straight swap.
The 3 teeth from the bulb holder are slightly different and don't fit into the lens.
Then thought id change the bulb holder but that didn't work either as the teeth/fork that goes from the bulb holder are a little bit longer and don't fit click onto the black plastic thing where the wires go.
Was wondering if anyone else has come accross this? if this was a VW re-desiegn down the track of the mk3? or just different between VR6 and other models?
'79 GLD
That's strange, I thought it was a straight swap between amber and clear front indicators. Have you double-checked the alignment of those teeth on the plugs? They're all in different orientation so only fits on one way - one teeth is straight, one skews in the clockwise direction and the other in the anti-clockwise direction.
yeah i did, many times. I realised that one length of plastic in between teeth is longer in one lens than the other, hence why the teeth (2 angled, 1 square) won't line up. I thought it was just me but it fit perfectly straight into the old orange one.
There were very minor differences between the 2 bulb holders which made me wonder if there was a difference between 94/96 or VR6 and others.
very confusing.
'79 GLD
Nope, I had the same problem when I swapped to clears (OEM ones straight from ze Mutterland aswell). Can't remember how we got around it, but I've still got the ambers lying around so I can check the solution for you some time?
That would be awesome, thanks
'79 GLD
Just had a look, it seems that we had no problem with the actual fitting of the indicators and it's all coming back to me as I type. One of the old bulb holders had corroded onto the black plastic thing so that was our only issue.
I swapped over the entire assembly including lens and bulb holder with no dramas? Sorry mate, can't help any further than that..
dang, thats really weird then. The clear indicators are original VW "made in Germany" ones but are just that little bit different.
'79 GLD
- You may not post replies
- You may not edit your posts
Forum Rules
