Anyone done it?? The 2 U-bolts provided measure internal sizes of 75 x 90mm. I'm told by Whiteline that this is the correct size, but from my reckoning they need to be 85-90 x 100mm. After calling their service centre I was told that they were a tight fit and may need to be bent a bit. Well, I bent it enough such that I could get it on, but now its 90mm wide and the mounting plate won't fit (holes are only wide enough to fit 75-80mm width). In addition, with the U-bolt on, albeit 20mm too wide, the internal length of 90mm is too short to be able to bolt the mounting on, as well as being too wide .
Has anyone else had this problem with Whiteline parts? The U-bolt measures what they say it should, but theres buckleys chance of fitting it to my car. Maybe my car is odd???
