Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: The infamous Golf MK3 CL....
    Nov 2006
    Central Coast, NSW
    Hey All,
    I just found this forum from google and man has it been great to browse so far....
    I just bought a CL and it has a few problems... just wondering if you guys can help out? i got an inspection before i bought it and spoke to a vw tech about it and he said most problems are pretty easy to fix.
    Problems:
    • Heavy leak at tappet gasket cover
    • slight leaks at timing cover
    • slight leaks at sump gasket
    • moderate leaks at rear main seal/bellhousing
    • brakes are spongey - (new brakes however)
    • engine is misfiring - i am yet to replace the spark plugs.
    another note is that the "cooling system pressure" is at 15psi - is that bad? what is the average?
    Last but not least, where the hell do i get head/tail lights from within australia?! lol. i also read somewhere here that most aftermarket lights are illegal... is this true?
    thanks a bunch already guys... waiting to hear from you...
    syncro Guest
    Quote Originally Posted by bboyskidz
    Should be OK
    Doesn't it come with lights?
    As long as they're RHD and E code, they should be alright.
    Nov 2006
    Central Coast, NSW
    Quote Originally Posted by syncro
    Yeh i comes with lights, but they are just the stock CL lights and they are pretty bland. i was thinking of going with the whole ninja theme (i.e totally black everything) and getting black tail lights with the chrome "angel eyes/projector" headlights.
    Question is, where to get them...
    syncro Guest
    Don't get them from the USA. (LHD)
    England has them.
    Camden, Sydney
    Problems:
    The leaks at the top are easiest fixed by taking the rocker cover off. 4 10mm bolts and a bit of messing about and wiping the rubber gasket and putting a bit of instant gasket above and below the half moon shape at eash end of the gasket. Then bolt the cover back on firmly.
    That may fix most of your oil leaks. Hopefull the rear main is not leaking and it is just oil coming down from above that you can see.
    The sump gasket can just be nipped up if you lie under the car and tighten all the bolts a little.
    We need more info on the misfire, when it does it. Under load? When cold, when warm etc.
    Welcome to the forum, I think you`ll like it here
    Nov 2006
    Central Coast, NSW
    [qoute=syncro]Don't get them from the USA. (LHD)
    England has them.[/quote]
    yeh thats what i thought... what are some good sites? none in aus?
    Quote Originally Posted by Golf Loon
    it doesn't do it under load, not that I can tell, but it does it on idle, whether it is hot or cold
    I think so too you guys all seem to know what you are talking about...
    Camden, Sydney
    ebay.co.uk
    Nov 2006
    Central Coast, NSW
    ebay.co.uk
    sweet, i was just thinking that myself...
    Sep 2006
    West Sydney
    Welcome to the forum bboyskidz
    Try some of these out, they supply aftermarket "enhancers" if you like, and are located in Australia:
    http://www.carmate.com/display_produ...ar=Version%203
    http://carshine.com.au
    Note that I haven't bought anything from these guys, nor have I visited their shops, so I really don't know what to expect from them in terms of service, product quality and prices. Hope it helps
    Camden, Sydney
    Shouldn`t you fix the oilleaks before spending money on fancy dress up parts?
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
