Results 1 to 10 of 17
Thread: Indicator/Tow ring solutions on shaved bumpers
    SE Suburbs, Victoria
    I'm very keen on shaving my bumper one day, but i still need my blinkers (Don't we all?).
    My Question is:
    What's the best solution to a shaved bumper indicator you've seen?
    And is there a law stating a certain height that indicators have to be off the ground in Victoria?
    This is a great idea and on white it would blend in nicely
    VWVortex.com - DIY shaved bumper and custom LED turn signals
    But i don't have the skills for LED, that and i think I'd like to keep the mk3 to its vintage.
    I've seen most people do this:
    1. http://i188.photobucket.com/albums/z...g?t=1257901053
    2. http://i58.photobucket.com/albums/g2...havedfront.jpg
    And there's a DIY thread here using the side indicator.
    Any more?
    Oh and what about the tow?
    Is it important/illegal with out it?
    Cheers.
    Jun 2009
    Auckland, New Zealand
    Another common one is to put some yellow LED's into the side of the headlight (as in behind the glass lens). Good opportunity to Joey mod them too
    One of the local guys here did it that way, but can't find pictures of it at the moment (I'll search again)
    In terms of the tow hook - I think you just don't worry about it, and hope not to brake down! Otherwise remove the bumper lol
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
    Jun 2007
    Eastern Suburbs Melbourne
    you could get mk 4 look-a-like headlights (if you don't mind/like the look) and use an indicator spot, just like a mk 4 would.
    Either that, or what something down in the lower grills I reckon.
    i like volkswagens
    Jun 2009
    Yep that's the one
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
    Apr 2010
    that being said, what would need to be done bodywork/structure around the headlights of the mk3 and grille n bar to fit the mk4 headlights? or would they simply fit with maybe a need to get a mk4 grille?
    Jan 2010
    Springwood
    just be mindful of ADRs,
    I believe there are regulations which relate to the angle and distance from which the indicator can be viewed.
    Side markers obviously make this alot easier...
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
    Jun 2009
    Quote Originally Posted by browndizzle View Post
    You wouldn't fit Mk4 headlights, it wouldn't work. He was talking about Mk4 look-a-like's, but they are still designed to fit a Mk3.
    You could do a Mk3.5 front end conversion if that did tickle your fancy though
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
    Jun 2007
    umm....
    you could get mk 4 look-a-like headlights ...
    mk 3 headlights fit straight into mk 3's..
    i like volkswagens
    Apr 2010
    the look-a-likes actually do need brackets and minor body work...
