Results 1 to 3 of 3
Thread: Indicator switch?
    Sep 2009
    Indicator switch?
    Hey,
    So the other day I was about to make a turn, hit the indicator and nothing. Jiggled it around a bit and it finally worked, then it worked fine for a fair while. Lately its been getting worse and more common, is a real pain trying to change lanes in traffic when you have to keep hitting the indicator to make it do anything.
    Am thinking that I might have to take the steering wheel off to get a good look, but chances are i will be looking in the wrong place or something anyway, since i don't actually know what im looking for... So yea if anyone has had a similar problem or can help out it would be very much appreciated.
    Thanks
    Jun 2008
    Hobart, TAS
    had the same thing happen, ended up being the hazard light relay.
    check that, the indicator relay and/or fuses. it's a fairly common problem, and an easy/cheap fix.
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Sep 2009
    thanks, will check it out later
