Originally Posted by
AALocksmiths
It could be the key but unlikely as the transponder chips rarely fail. It could be the key reader which you can kinda check with a test light, you an make sure that it is getting power but this won't rule it out 100%. They are not coded to the car so you can swap it over to test.
I have had then with faulty immobiliser boxes but again it's rare. It is possible to clone your Immo box and write the data to another if needed.
From the fault codes it looks like there is no Immo fault in the Immo box, if so it is reading the key and is happy with it. The fault may be the wiring between the Immo box and ecu.
