Results 1 to 10 of 11
Thread: idling rough/cutting out
    Jun 2013
    Exclamation idling rough/cutting out
    Hey guys when I start my car up it tends to idle rough, and a tad lower than usual.
    Then, when I step on the accelerator it bogs down. It's not until I completely redline it till it runs normally.
    It's no trouble when driving, just annoying to start sometimes.
    It's worse on cold mornings too.
    thanks
    420 dank blaze it
    Sep 2009
    Re: idling rough/cutting out
    Id look for a vac leak first.
    Edit: what motor is it?
    Sent from my GT-I9305T using Tapatalk 2
    Oct 2011
    Full car specs would be helpful. Could be a Barina.....
    Jun 2013
    95 Golf 2.0L GL
    there ya go boiz
    420 dank blaze it
    Adelaide hills, SA
    Quote Originally Posted by gere View Post
    95 Golf 2.0L GL
    there ya go boiz
    Where in Adelaide are you?
    Jun 2013
    Pasadena area, just south of the city man
    420 dank blaze it
    Oct 2011
    Sounds like you need to do some trial an error. Considering its more or less on cold mornings start with the cheapest thing and replace the spark plugs, then go from there. coil packs, check and tighten all intake hose work. Given it is an older car now you may be due to renew a bunch of ignition parts.
    Quote Originally Posted by Tarmac View Post
    No coilpacks, just one coil and that would just quit straight up.
    Definitely look for dodgy vacuum lines first.
    Mar 2013
    Northern Beaches
    Sounds like you may have the problem I had. I had a hole in my idle valve
    I replaced it with some other tube that was similar (just had to cut length off) from Repco and it's as good as new now. Been meaning to put it up on my thread, I probably will when I get home so keep an eye out ! Hopefully it'll help!
    Jun 2013
    Thanks a heap for the responses guys!
    Would it be worth getting the car looked at by a mechanic first before persuing any work?
    Just to save money, thats all im thinking of haha
    420 dank blaze it
