$30 each at australias bests on canterbury road
how big do you want the spacers to be i think is the first question??
I was thinking 10 or 15mm, wider at the rear. Basically as wide as my car will allow. my problem is I'm already quite low with koni's and Eibach's and my tires are 215/40/17. Yes I may rub a bit and I don't really think its possible to roll my guards with the plastic flares on them...A smaller tire, even a 195 may be in order to solve the rubbing issue. I do want my rim flush with the guard though...even if its a hassle getting it there!
Can I solve this?
Alex.
1983 Lotus Esprit Turbo
2013 VW Golf MkVI Cab
Looking for a blue MkIV R32.....
As george pointed out at the last bbq inside ur guard these a really small lip that juts out horizontally that u can roll up if u really need to. Its about 10mm and that should be easy to do.
talk to mk3vr6,he has the plastic guards as well and he had his guards rolled.his rears are 15mm I think.you will find that if you dont have coilovers ,where your able to raise or lower the car,will be the problem..
