Results 1 to 7 of 7
Thread: I think it's electrical...
    Jun 2013
    Exclamation I think it's electrical...
    Car has been overheating while driving around, however the fans dont come on.
    It's really frustrating gaaah
    I took it to a mechanic and the suggested that it was electrical... are they on the right track?
    thanks
    420 dank blaze it
    Mar 2012
    melbourne
    if the cooling system is fine then the fan control module is most likely the cause.
    its under the expansion tank. does your ac work?
    Jun 2013
    nah my ac comes on and off sporadically.
    420 dank blaze it
    Jan 2011
    Rooty Hill, Sydney
    Usually it's the fan switch, sometimes the actual fan it's self
    or as some have said, the control module.
    It quite easy to test if it's the fan switch though. pull the connector out, get a piece of wire (make sure the wire is insulated) and joint two of the terminals and it'll fire away.
    I'll post up later which two terminals carnt remember rite now.
    Garage:
    VR6
    XR6
    R36
    Jun 2013
    thanks for the feedback
    I was considering just taking it into an electrition to save both hassle and to save breaking something (bound to happen knowing me)
    420 dank blaze it
    Mar 2012
    melbourne
    its your fan control module.
    the ac being intermittent proves this.
    easy fix.
    Jun 2013
    thats good to hear!
    thanks
    420 dank blaze it
