which codes did you actually throw? do u know?
Yeah, engine speed, cam position, lambda probe. Seb reckons if all three are inactive then the car won't start so we're re-scanning it to see which of those (if any) are faulty.
Haha ok...I figured things like that aren't expensive, but the thing I thought would make the job difficult is the positioning and accessibility of all the sensors....I was told the lambda is in the exhaust somewhere and i'm assuming the cam angle sensor is somewhere near the top, maybe underneath engine covers?
What I'm trying to ask is...can i do it myself easily? lol.
the lambda probe is on the pipe before the cat its a 22 mm
the cam angle sensor i havent changed but id be able to find it bring your car here and il do them for you in exchange for a 6 pack of golden ale
cam position sensor is at the front of the engine on the gearbox side. You need to remove the coilpack from memory to get it out. Only takes a couple minutes to change if you have the right tools for the job.
But yeah. Obviously bigger fish to fry at the moment.
Thankyou again to Seb for the scan and the advice! I went back yesterday and the car threw all three codes again. The car is running too rich, so it looks like the timing may be advanced by a tooth so I'll need to check the cam timing.
