Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: I can't work it out
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by decksla View Post
    put the old coil pack back and see if you still have the problem.
    but before you do, have a REALLY good look at the one youve just mounted and make sure you havent over tigthend the bolts and cracked the housing.
    if you have, youll have the problems you speak of. theres also a thing you can do with a water bottle spray. with a car on idle, spray the coil pack with a fine mist. if you see little sparks, your coilpack is damaged in some way.
    just my 2c
    Might try that next week with the old coilpack. I'm not spraying the new one! lol. Cheers.
    The problem seems to have dulled down now that the codes are cleared. Next week will tell me if any of those sensors need replacing.
    Point Cook, Vic
    which codes did you actually throw? do u know?
    FOLLOW US ON FACEBOOK
    Dec 2007
    Ermington, Sydney
    Yeah, engine speed, cam position, lambda probe. Seb reckons if all three are inactive then the car won't start so we're re-scanning it to see which of those (if any) are faulty.
    Oct 2006
    sydney
    Quote Originally Posted by Mrk_Mickey View Post
    well change them anyway
    lambda probe $90
    cam angle sensor $75
    sound of a problem free healthy VR6 engine.. priceless
    so start doing more hours at woolies
    Dec 2007
    Ermington, Sydney
    Haha ok...I figured things like that aren't expensive, but the thing I thought would make the job difficult is the positioning and accessibility of all the sensors....I was told the lambda is in the exhaust somewhere and i'm assuming the cam angle sensor is somewhere near the top, maybe underneath engine covers?
    What I'm trying to ask is...can i do it myself easily? lol.
    Oct 2006
    sydney
    the lambda probe is on the pipe before the cat its a 22 mm
    the cam angle sensor i havent changed but id be able to find it bring your car here and il do them for you in exchange for a 6 pack of golden ale
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by william View Post
    That's alright mate thanks for the offer but I prefer to get stuck into it myself Although I've got a smash to worry about for now
    Point Cook, Vic
    cam position sensor is at the front of the engine on the gearbox side. You need to remove the coilpack from memory to get it out. Only takes a couple minutes to change if you have the right tools for the job.
    But yeah. Obviously bigger fish to fry at the moment.
    Dec 2007
    Ermington, Sydney
    Thankyou again to Seb for the scan and the advice! I went back yesterday and the car threw all three codes again. The car is running too rich, so it looks like the timing may be advanced by a tooth so I'll need to check the cam timing.
