Lie on the road in front of your car. There are some 10mm bolts along the underside of the bumper looking up, might need to move the two black grilles. 5 bolts all up I think.
Then remove the plastic covers next to your indicators, gently with a small screwdriver. 2 More bolts. Disconnect indicators now.
Check its not attached to the wheel arch liner on each side, grab it and firmly pull towards you.
If it wont come there are more bolts.
Hope that helps you Golfer![]()
