Results 1 to 5 of 5
Thread: how do I check auto fluid level in our GL
    Feb 2014
    Yankalilla, South Australia
    It's the 95 GL with 2.0 motor and auto, and I can't see the dipstick, maybe I need to have a better look?
    Q
    Quote Originally Posted by Roger View Post
    1. With difficulty
    2. There isn't a dipstick
    **runs away**
    (I'll let the pros step in as I'm a muppet with no clue, but I know it's a PITA, under the car there's a skid plate to protect the g'box, in behind that you can pump oil into a feed..............surely VWVortex has an epic how to)
    Dec 2008
    Sydney/Canberra
    Start it up, remove drain plug, and see if any oil drips out. If no oil drips out, add oil.
    You need to gravity fill them from the drain plug.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    as above, but also make sure the car is levelled.
    Feb 2014
    Thanks, I found the drain/filler, I'll top it up.
