Results 1 to 3 of 3
Thread: How do I change VR6 oil cartridge....
    Sep 2006
    I have just bought a new oil filter cartridge for my VR6 but am a little concerned about getting it out. Before I dropped the oil I thought I would ask you guys if you have any tips on accessing/removing the cartridge. It seems that two tubes for the air-con are in the way. Is there any trick to getting it out, or do I have to disconnect the A/C tubing? I don't want to drop the oil to then find I am unable to get the cartridge out.
    Thanks in advance!
    Point Cook, Vic
    its pretty easy if u have the right tools.
    There is a small allen bolt u undo from the bottom. it drains the oil out of the filter.
    After that u unscrew the big plasic section from underneath. Its MUCH easier if u have a 36mm socket as the plastic deforms if the person that has been at it b4 hand has done it up stupid tight. I found that out the hard way and had to go buy a socket for mine.
    other than that its pretty much the same as any other oil change. I usually put a bit of oil back in there b4 putting it all back together(saves having no oil pressure for a few seconds) And the new filter usually comes with a new O ring so might as well replace that too.
    but yeah. easy peasy
    FOLLOW US ON FACEBOOK
    Sep 2006
    Thanks Tim. I was actually looking at the wrong thing (silver thing, at the front of the engine facing forward). It looks like it could contain a filter cartridge. Anyway, got it sorted now, very straight forward change.
Similar Threads
  1. can you change the clutch friction point?
    By BL33SU in forum Passat (B4 & B5)
    Last Post: 07-03-2007, 07:13 PM
  2. Oil Change
    By DIDZ in forum Mk4 Golf & Bora and New Beetle
    Last Post: 30-12-2006, 11:36 AM
  3. Cable change gearbox conversion
    By twin eng, twin turbs in forum Restorations, Conversions and Projects
    Last Post: 25-09-2006, 10:48 PM
  4. Cam belt change on MK2 8V
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 14-12-2005, 07:58 AM
