for stock strut that is normal (pic above), i dont know if coils should be the same...
So had a quick go at the fronts, this was the result.
Bearing in mind the very top is not all that tight yet, is this right? I may just hand tighten it best I can manually, then drive to my neighbour's shop and use the ole impact wrench to get it done better. How many mm should there be between the top of the strut tower and the top cup thing?
