Wheel bearing?
Does it undulate in pitch as you change speed?
On the drive home last nite heard this high pitched noise as i was driving along, pulled over and had a look. Nothing seemed wrong(but then i know next to nothing about cars), started driving again and the noise disaapeared.
any clue as to what was the cause of the noise?
thanks in advance
-Josh
- 95 VW Golf VR6
Wheel bearing?
what sort of noise? either a wheel bearing or sometimes stones can get caught in between the discs and the brakes or brake shields if u have been driving on unsealed roads. That happened to me in tassie. It was very embarassing as we pulled back into the chalet car park as the noise it was making was sooo painful!
the pitch did get higher and louder as i accelerated. but mayb it was a rock, i litierally just got my car bak from a checkup day be4
- 95 VW Golf VR6
well if its a rock then try reversing a bit to flick it out backwards, thats what i do when i get a rock stuck in there. it has happen a fair bit with my gf's outback. jack the back side of the car up and spin the wheel around to see where the nosie is coming from. if the wheel can move in and out at all then the bearings need to be adjusted or changed if there broken.
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
If its a rock check then you can move slightly the metal sheet at the back of the disk and force it out there!
thanx heaps everybody!
- 95 VW Golf VR6
The fuel pump is also near the right rear of the car. Something to keep in mind![]()
heard it again just then on the way home, was accelerating up hill; stopped the car and didnt hear it again.
its almost like a kettle boiling that sound
- 95 VW Golf VR6
