Welcome to VWwA Joey![]()
Only a money pit if they havent been properly maintained, much like any performance car.
have it inspected and make sure they look at lower control arm bushes, strut tops/bearing, engine mounts etc.
any car with k's on it >150 you may be looking at replacing the clutch.
probably the best 3 questions to ask are:
Has it been regularly serviced
Has the clutch been replaced
Has the heater core ever been replaced
If no to any of the questions tread lightly.
My car had regular services some not at a dealer, the heater core is fine (touch wood), and at just under 200k on the clock when the clutch went.
It also was owned by a guy who obviously never gave it any stick as it blew smoke for a couple of weeks any time you pushed past 3500rpm hahahaha
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
Hi Joey, mate don't listen to some of the cars are money pits yes you do have to spend money on servicing and maintenance but they are all the same!
If you find a good one you will probably still have to put money in to it but not as much as you think. Best thing is to take a mechanic with you as well as they will obviously know alot more than anymore and will be able to pin point you to the problem and then bargain that price down with the owner of the car. Welcome to the forum and good luck with your search for the vr
Where abouts are you form if it may help that you come have a look at a few so you know where abouts to look for the problems!!!
Hey guys, thanks for the warm welcome.
I live in western sydney.
When i find the car i wanna purchase..i plan for it to be inspected regardless, so i hope they can find the faults there.
What has really caught my attention is this one advertised.
http://www.drive.com.au/used-cars/VO...1&SG=822057019
I've been eyeing on that one too. Started off 13,990 I believe. Have you been to that dealer and seen it yet?
heyhey! another VR convert (nearly) . . . good to see you found VWW! did you jus google it?! . . . jus wanna add that make sure you can see that it's had regular services! logbooked even! i bought mine with a full vw dealer logbook service history and 280k on it and NO problems so far! (touch wood touch wood touch wood touch wood touch wood). . . so yeh jus do wat others hav suggested and you'll be fine
good luck finding one!! laterzzzz
Ray: im aiming to see it on the weekend. I hope its A1 thou!!!
Can any1 help me locate the Heater Core???? Where is it located and how do i identify if its been repaired/replaced etc.
Its inside the dash and its a bitch of a job to change thats why check to see if its working or not. If the heater core is gone the coolant pipes to the heater are blocked off or rerouted. Also, obviously the heater wouldnt work.
No way to tell if its been replaced other than going on the word of the seller. Let us know how you go after seeing itHopefully u should be driving a vr6 on monday lol.
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
Yeah it is, isn't it... good luck with the inspection!
