Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: Hesitation and poor throttle response: VR6
  1. #41
    Jan 2009
    Melb, VIC
    Bizarre! I only thought it was electrical related because it would come at a surprise that you'd be having fuel issues down low and not have any issues up higher in the rev range while under load.
  2. #42
    Jan 2007
    Well the car is running better, but strangely enough now only begins to develop this problem AFTER 25-30 minutes of continuous driving. If I was to return to the vehicle after say 30-45 minutes it would continue to missfire at low rpm in the same was as described before. I'm going to try to re-set the ECU and see if that makes a difference.
    Here is some good reading I have found in regards to a similar problem some 10 odd years ago in a late model VR...
    http://www.gti-vr6.net/library/engine/95_stumbles.html
