Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: Hesitation and poor throttle response: VR6
  1. #31
    Oct 2006
    sydney
    plugs and leads and notice the difference. if it has been stalling then i would say the coil or do all and not worry about anything it will cost you $500
  2. #32
    Jun 2007
    Central Coast, NSW
    The other mechanic i took my car to last week found the culprit... Timing chain tensioner broke, and skipped a tooth on the front cam causing it to do what it did. Once he opened it up, had about 10-15mm of give on the chain... So a lot of money later and I should be back on the road next week, hopefully with nice compression and 0 hesitation
    -Sven
  3. #33
    Mar 2008
    Quote Originally Posted by svedo View Post
    What's a lot of money? We're talking about a VR6 here..
  4. #34
    Jun 2007
    Central Coast, NSW
    Ha too true, I've officially named the black beast "the money pit" now, I doubt if I'll get much change from 3k (not a nice bill to have straight after xmas), haven't got the final grand total, only cause there was a couple other things that I'm getting fixed up while its in bits. Didn't seem to bend any valves which is a good thing.
  5. #35
    Jan 2009
    ADL
    yr scaring me now, my timing chain has started rattling again - blamed it on thin synthetic oil for a while, how bad was the rattle before it skipped?
    96 VR6, Black
  6. #36
    Jun 2007
    Central Coast, NSW
    Mine rattled for quite a while, but I had one of the tensioners replaced when I had the head gasket go, so that bought me a bit of time. It was a couple months ago, it started to sound really bad. From what I've been told though, its one of those things you want to get sorted before it goes 'ping', as bad, bad things can happen if it does.
  7. #37
    Jan 2009
    Melb, VIC
    My vw had the same symptoms, i checked the leads time and time again thinking they were okay but alas they were arching / shorting on the head. I only noticed this when i had the car in the garage without any lights on.
    Car popped and farted just like yours but once it got over 3 - 4000rpm it purred like normal.
    ps. Cylinders 2, 4 & 6 are the front cylinders ie. kissing the radiator
  8. #38
    Jan 2007
    Quote Originally Posted by william View Post
    This is where I got mine, $250 to your door in 10 days http://cgi.ebay.com/ebaymotors/VW-Co...Q5fAccessories. Did make a big difference initially but then I realised there was more than one misfire going on at any one time. The car is running better atm, but is still missing below 2000. I'm going to order a new adjustable FPR and have that fitted along with some other things when I get the chance...
  9. #39
    Jan 2009
    Melb, VIC
    Quote Originally Posted by Golf Houso View Post
    Have you pulled your plugs and checked them recently? Is there even colouring over all 6 cylinders?
  10. #40
    Jan 2007
    Quote Originally Posted by pisana View Post
    Yeah I've had them all checked, no6 had the rubber damaged on the ignition coil side and was swapped with a lead from an odd set. The spark plugs have been changed recently under my ownership and leads themselves are quite new and look less than 12 months old, I have the receipt for them which confirms this. The spark plugs on the other hand, were by the build up of residue and white chalky deposits were either original or had been replaced near when the car was new. This was despite the two receipts in my possession which claim they had been replaced at least twice
