Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Hesitation and poor throttle response: VR6
  1. #21
    Jan 2007
    Monkeyland
    Quote Originally Posted by Tim View Post
    Sounds to me as though you still have a dodgy lead somewhere.
    I agree. Leads.
  2. #22
    Jan 2007
    Quote Originally Posted by dubbed View Post
    Well it's not a definite way of concluding that it's the MAF. Maybe you could try swap a MAF with another VR6 owner?
    It'd be worth a try definately, as for the leads no 6 was loose which I promptly put it back in its place. Its not running like a WRX anymore but this misfire at low RPM persists, and the leads are OEM and have been replaced by the unfortunate previous owner within the last 12 odd months.
    I'll do some more research and see what I can come with anyway, oh and please keep the suggestions coming
  3. #23
    Point Cook, Vic
    Its funny how much a vr6 running on 5 cyls sounds like a wrx isnt it hehe.
    id say its time to break out the vagcom and make sure all your sensors are working properly
    FOLLOW US ON FACEBOOK
  4. #24
    Jun 2006
    Orange NSW
    My mate had this issue with his when he had it. Turned out to be the fuel pump in the tank...
  5. #25
    Apr 2008
    Hmm well if it's just misfiring now I'd be trying a new set of leads - sometimes you can get dodgy ones that let go after a few days/months.
    It must be a VW thing. When my MAF was stuffed in the 1.8t my girlfriend said, "what are you trying to do, make it sound like a WRX?!"
    2000 Mk IV GTI
  6. #26
    Jun 2007
    Central Coast, NSW
    Hey Branko,
    Just an update from my neck of the woods, I ended up taking it to another mechanic up here, all the new parts put in passed with flying colours, but bad news struck when they did a compression test. 3 outta 6 cylinders are low, one loosing ~40psi.. Leak test was done this morning, but nothing found there... Not looking forward to the next phone call thats for sure...!
    -Sven
  7. #27
    Quote Originally Posted by svedo View Post
    Hey Branko,
    -Sven
    Is it the rear 3 cylinders that are low? What was the cause, top end(valves) or bottom end bores??
    The rear cylinders often get more worn than the front due to the angle the pistons run at. Especially if service intervals are not adhered to properly.
    Lots of piston slap VRs in the UK with only average mileages on.
  8. #28
    Jun 2007
    Central Coast, NSW
    Hi Gavin,
    It was cyl 2, 4 and 6, can't remember if thats front or back?.. Cause is still unknown at this stage, should get a call this arvo or monday with some more progress..
  9. #29
    Jan 2009
    ADL
    my 5c worth
    before spending big get some electrical contact cleaner from super-cheap and clean all the temperature sensor connections - -that's the ones in the group of three on the front of the engine and the intake air temp sensor on the top right of the engine as you look at it right behind the fuel pressure regulator...I once forgot to reconnect that little sucker and the car ran BADLY
    96 VR6, Black
