Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Hesitation and poor throttle response: VR6
    Jan 2008
    Newcastle, NSW
    Could it be a dirty fuel filter/dirty injectors Branko ??
    Jan 2007
    Quote Originally Posted by schoona View Post
    Changed the fuel filter, don't know about the injectors though.
    I just drove the car around and its a bit better than yesterday, but not by much. The car is basically misfiring at below 3000rpm, this is most noticeable when the car is cruising in 4th, just it doesn't so much as "cruise" as begin imitating a WRX misfiring continuously until you hit over 3000 rpm
    Perhaps get someone like Petroject to clean the injectors.
    Sounds like you're replaced everything else in-line, apart from the Fuel Pump Relay. If the relay was intermittent, you'd get symptoms like this.
    Very easy to swap in another pump relay to test.
    http://www.cardomain.com/id/sydvr6
    Subaru WRX Wagon 06 + Peugeot 306 GTi6
    Jan 2007
    Quote Originally Posted by sydVR6 View Post
    Perhaps get someone like Petroject If the relay was intermittent, you'd get symptoms like this.
    Well... here is something rather disturbing about the car, see the thing is there is no Relay 30, its been bypassed and even without relay 36 the car still manages to run
    Apr 2008
    I'm gonna have a guess and say MAF. Have you tried disconnecting it when the car is running? That's how I diagnosed mine (it ran better when I disconnected it when it was running). Good luck.
    2000 Mk IV GTI
    Jan 2008
    Newcastle, NSW
    Soundsl ike Seb got it straight up then.
    Jan 2007
    No errors came up on Vag com, I'll try disconnecting and reconnecting it now..
    Jan 2007
    Nope, with or without the MAF the car is still missing it didn't make any difference at all.
    Point Cook, Vic
    Sounds to me as though you still have a dodgy lead somewhere.
    FOLLOW US ON FACEBOOK
    Apr 2008
    Quote Originally Posted by Golf Houso View Post
    Well it's not a definite way of concluding that it's the MAF. Maybe you could try swap a MAF with another VR6 owner?
    2000 Mk IV GTI
