Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: HELP!! Vr6 not behaving!
    Feb 2009
    Thornton, VIC
    Quote Originally Posted by peedman View Post
    If it is indeed the crank sensor then u will get no fuel and no spark. Pull out a plug and see if it sparks at all, if yes then its something else. I would clean the isv and throttle out and see if it helps with the hesitation. Btw is ur battery ok? Its not losing charge overnight?
    nah its not the battery or alternator its turn over strong but just doesnt catch will try cleaning though!
    thanks
    Feb 2009
    Thornton, VIC
    Quote Originally Posted by Shteifen View Post
    pretty sure fuel filter is near RH rear wheel. just at the back of the seat. have to get at it from underneath though. im pretty sure its there though i might be confusing it with a newer car.
    -steve
    hey steve,
    when changing the fuel filter do i have to depressurize it or something if so wats the best way??
    Jul 2007
    Rowville Melbourne
    nah just go ahead and take the lines off, but WEAR SAFETY GLASSES.
    fuel will spray everywhere for a second but itll go away dont worry
    if you leave the ignition alone for a little while the pressure should bleed off slowly anyway. and by a little while i mean like....5 or 10 minutes and it should be mostly gone, or atleast significantly reduced. but i wouldnt wait, just wear those safety goggles and go for it, thats all ive ever done
    -steve
    Jan 2007
    Quote Originally Posted by 79golfgld View Post
    hey steve,
    pull out the fuel pump fuse, then run the car until it splutters and stops.
    Easy
    Jul 2007
    Rowville Melbourne
    right, you could do that!
    its past my bed time
    -steve
    Dec 2007
    Ermington, Sydney
    Don't you just yank the old filter off and put the new one on and turn the key so fuel goes through it (it takes a few goes) ??? That's what I did, lol.
    Perth, Western Australia
    your ment to open the fuel filler cap, well that wat they taught me at tafe =p to get the pressure out of the system or its just gonna keep pooring out and you'll loose fuel. if u do this you will just loose abit
    1995 MK3 Golf
    Dec 2007
    Ermington, Sydney
    Meh I caught my fuel in a bucket and poured it back in when I was done hahaha.
    No fuel was caught from my old filter though!
    gold coast
    dude first thing i would be checking from what you have said is your fuel pressure regulator as its probably weak or f**ked and as soon as you turn the car off and the fuel pump stops the fuel runs straight back to the tank from the rail then obviously it takes time to pump it back up from the tank to rail resulting in taking a few cranks to start but fine when running.
    my vr is exactly the same as we speak and i already have my new shiny aftermarket regulator to go on
    give it a shot man. id put money on it. . . .
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
