Results 1 to 6 of 6
Thread: Help! VR6 Brake light problems
    Jun 2011
    Long story short:
    Got defected last Friday and its booked in for inspection at the pits on Friday.
    I put in the original indicators and air box and now my brake lights don't work... None of them.
    I checked the fuse and its not the fuse. Any ideas? I'm screwed if i can't fix this soon!
    Honda Civic Owner
    Dec 2008
    Sydney/Canberra
    Globes?
    I'd say the switch, but generally if that fails, the lights stay on all the time.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2011
    I have my doubts that all 3 of my brake lights blew globes at the same time. My guess is the switch. Would that be something I could fix in 2 days
    Honda Civic Owner
    Feb 2010
    Quote Originally Posted by TidyVR6 View Post
    have you got a multimeter?
    above the brake pedal is the switch, i would be testing that the switch is actuating. if not as mentioned before that would be the issue.
    if it does work then test the relay.
    hope that helps
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Sep 2010
    Wantirna South, VIC
    Check your globes. I encountered the same issue once, all brake lights went out and fuse was fine. Turned out the globes decided to die all at once.
    Jun 2011
    So its definitely the switch. I had a fiddle with it and got it working last night. Got home tonight though and the lights weren't working again. May have to invest in a new switch!
    Honda Civic Owner
