Results 1 to 9 of 9
Thread: Help Required - Spring Compression
    Jun 2013
    Melbourne, Australia
    Hi Guys,
    I'm in the middle of replace my suspension mounts on my VR6.
    I've removed the strut and compressed the springs enough to remove the top hat and existing top mount.
    I'm trying to reassemble it but for some reason I can't compress the spring enough to reassemble.
    Am I missing a trick?
    I've done this to so many car in the past but this is the 1st time I've ran into this issue :S
    2012 - Tiguan - 155TSI - DSG - Black
    Quote Originally Posted by UKDavo View Post
    Hi Guys,
    The only thing I reckon could have happened is the piston has fallen into the housing. As it's probably not a gas one. Just pull the piston out before trying again.
    Jun 2013
    I've got the strut completed dismantled with the spring off, I'm trying to get the spring to compress enough so I can screw the hat and nut on top but the spring physically won't compress enough :/
    Jun 2011
    Spring compressor's?
    Jun 2013
    Got them but they won't compress the spring enough.
    I'd prob need 4 :/
    Dec 2008
    Sydney/Canberra
    As Gav said, pull the shock shaft up. They sink into the strut housing.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    As per above and gav.
    Jun 2013
    God I'm an idiot, yep Gav you were right. Thanks guys!
    LOL, sometimes it's the easiest things that get in the way
