Results 1 to 10 of 17
Thread: Help! Oil part that I can't name is broken!
    Jan 2013
    Redfern, NSW
    Hi,
    This oil filter part has broken for the 2nd time. I had previously cleaned it up and used JB Weld to glue it back together but alas it has completely snapped off again. I seem to be going through more oil that usual so need to work out a fix for it. Has anyone replaced it with an aftermarket piece? Does anyone have a spare one off an old engine? Any help would be greatly appreciated. I'm located in Sydney.
    Thanks,
    Dan
    Mar 2014
    Bundoora, Victoria
    PCV, get a new generic length of pipe and JB weld it.
    Edit;
    Find part similar to this one PCV Valve Elbow - Dorman (47037) , any part will do, just make sure you can get it to fit. Should be able to find it cheap.
    Past - '95 VW Golf MK3 VR6
    adelaide
    i have seen images of people just putting one of these oil breathers straight onto the outlet from the engine?
    mine is also broken.. is this a simple cheap solution?
    Attached Thumbnails Attached Thumbnails Help! Oil part that I can't name is broken!-16724465_12-jpg
    1996 VR6 Golf
    Mar 2014
    Bundoora, Victoria
    Considering oil vents from the crankcase from that outlet, that small filter will become oily very quickly unless it's good enough to to keep oil inside the crankcase and only let the pressure escape from there.
    Idea is when the crankcase vents some oil is let out as a vapour. This then goes through the PCV and then back into the system via the intake. On other cars this is where people attach their oil catch can if they don't want spent oil cycling back into the system.
    Sep 2006
    West Sydney
    That's the quick fix, blocking off the intake side and popping on one of those breathers, but like stefcio mentioned and as you can imagine, they will get drenched with oil very quickly.
    You could delete the PCV and run an oil catch can? Basically run a hose to the inlet of the oil catch can from the engine side and connect the outlet with the intake. Does the same thing as the PCV does basically, but instead of having a dirty intake, it'll all go in the catch can which you should empty every service.
    Jan 2013
    Redfern, NSW
    is that the oil catch can down under the air filter? does the oil travel all that way? there is also another hose that connects to a tiny pipe on the intake side of the PCV. Is that important? I'm going for another JB Weld just to buy some time but like the idea of the catch can...
    Jan 2011
    Mt. Waverley, Victoria
    I just ran took the PCV off and ran a hose between the breather and the intake
    '95 Golf VR6 Colour Concept
    Sep 2010
    Southern Highlands NSW
    403 Forbidden
    also 42dd have a replacement bit instead of using a hose
    im guessing that tiny pipe you are talking about is the feed to the carbon canisiter?
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    Sep 2010
    Mk3 VR6 PCV Fix
    I used this on my previous VR6
    I recently had to do one again on my Vento but this time went with a brand new oem replacement like the one from ecs
    be aware that if you do buy a new unit it is only sold as complete with the intake boot/elbow and that there are 2 different models for the Australian delivered cars
    Polo GTI
    T-Roc R
    Tiguan R
    I've just got mine feeding straight to the intake.
    Will be swapping to a catch can later
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
