Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help Installing a towbar
    Aug 2012
    Hey there i need to install the wiring for the towbar.
    Buy a DIY kit and follow the instructions??
    Also people have told me for my Vr6 i need a ECU for it?? True??
    Dec 2008
    Sydney/Canberra
    Highly unlikely it'll need a separate ECU.
    Just tap into the relevent wires for each light (1 tail, 1 brake, 1 for each blinker), and go from there. For the earth, there's bound to be an earth point somewhere in the back of the car not far from the tail light wiring.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2009
    Geelong, Victoria
    sounds unlikely, no issues putting a towbar on a mk4 so a mk3 shouldnt be a problem
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Aug 2012
    Thanks for that however when I do install it
    How could I tell if I need a ecu??
    Jun 2012
    wollongong
    Should be pretty straight forward installing it. As for the wiring exactly as "umai naa!!" Said you can just tap into the relevant wires and wired it to the socket. There might be a oem harness for it which should be plug and play but I don't know whether they came from factory with a towbar
    Something new
    Aug 2012
    I've order my wiring harness with the cable today
    Ill install it when I get it
    I'm only worried I would damage my computer cause I didn't install a ecu
    Jun 2012
    wollongong
    You won't destroy your computer all your doing is extending your tail lights, the signals won't go anywhere near your computer
    Something new
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by SXY28L View Post
    Very doubtful this will happen, I really shouldn't worry.... i'm assuming the harness just plugs into the passenger side tail light? all should be fine
    Mar 2009
    UMG Brisbane
    Both sides (needs drivers side indicators). 'ECU' just stops the car from getting tail light error - not sure if that is gonna be an issue with a Mk3
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Sep 2006
    Quote Originally Posted by 99_FGT View Post
    pretty sure with the mk3's one tail runs from the other? could be wrong though...
