where do I get a left hand side black plastic strip from m Brisbane?
need Black plastic side strip for 96 VW golf Cabriolet
any ideas?
http://i693.photobucket.com/albums/v...psfydk2tuk.jpg
okay will do. good advice
Quote:
Originally Posted by
Mk3 AAA
Side stripes should be the same as the three door hatch, so pop a WTB ad in the parts/ wanted to buy section and you might find something, otherwise there are a couple of euro wreckers that might have one.
On will do good advice
aftermarket headlights need adjusting - hope someone can help me?
hi All
Been a while since I have been on here, the MK3 has been good .
The headlights need adjusting hope someone can help me. The PO replaced both headlights assemblies with different types with led halo rings. So I can't just follow the book. The dont seem bright enough to me but first thing is to make sure the angle is adjusted .
the Golf manual says on the stock units there are 2 screws a) up/down b) left right b but on this set up I can only see one o'bvious screw but this assembly is different
I dont want to go screwing it in and out without knowing if i need to loosen any other screws?
http://www.vwwatercooled.com.au/foru...qgarem1b-1.jpg
you can see the screw above the light wiring
http://www.vwwatercooled.com.au/foru...la5esar6-2.jpg
