Good ending! well sortedwill keep an eye out for this on the roads
it's obama, he drives a passat.
1995 MK3 VR6 - Green - Black bits - Wheels - Tyres - Engine - Etc........
ಠ_ಠ
Hi all
the 96 red mk3 is up and driving around, its clutch is getting a real hiding from my learner driver daughter! she has only ever driven in a auto so this clutch is something new for her.
I have an intermittent front passenger electric window problem, sometimes it won't go up or down. Seems to me it could be a switch or the motor . any ideas on how i fault find?
also is anyone familiar with the cabrio electric hydraulic roof? Right now the dash switch will I can close it but not open it . lucky i can manually operate it by opening the hydraulic valve
thx paul
if you need another switch to test I have a spare... i've bought two of everything involved with the hydraulic roof but mine is still non-functional![]()
Thats real good of you. do u mean u have a spare roof switch as well as door switch?
MK3 Electric windows are ticking time bombs, they will break (I replaced 3/4 of the ones in my VR6 before I sold it). It's rarely the motor and usually the regulator which can be bought new for ~$250 or so from VW. Well worth the price to have trouble free window winding for the next 10 years.
I do have a real soft spot for the MK3 Cab... seriously considered one for myself but ended up going a slightly different way![]()
if you have about $250 spare you can also order a VAG-COM interface to be able to read the ECU. I had a hall sender issue but mine was a simple adjusting of the timing. You can also read and clear errors as part of your service regimen. Got mine through German Auto Parts (US) and downloaded software on my netbook so I can plug it in and test, diagnose and adjust away!
Ross-Tech: Home
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
