Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Headunit Install
    May 2014
    Newcastle, Australia
    Get 6.5 components for the front and run the tweeter in the top of the dash spot, that's what they are originally and you get good sound off the windscreen. 2-way 6.5's are best for the rear due to basically no place to put a components tweeter, the stock hole is far too small for anything aftermarket.
    Jun 2011
    Quote Originally Posted by cliftronix View Post
    4" pioneers in dash tweeters work for extra doof
    Apr 2008
    NSW
    Would that be a separate purchase Hayden if I were to get the 4"? The 6.5" components already come with tweeters but not sure if they will fit in the OEM location above the dash?
    If the 4" are separate speakers which need to be purchased, i might just forgo it for the time being...
    Jun 2011
    4" components are seperate. I paid $70 installed from a local audio shop.
    Just make sure they don't have a big fancy cover over the speaker otherwise the grille won't fit back on
