i had a problem with the cable from the relay to the stater motor in my cl, i fixed it by bypassing it, got a cable, and ran it through a hole just behind the glove box to a switch that i taped just by the left leg. the cable went straight between the starter motor and the battery, the button switch just conected the two and all was fine, starts reliably. and passed rego.
um, could also be a distributor cap, just had to replace mine, and is running fine, also, check the ignition coil up the top of the engine bay when running, there may be sparking across from from the coil to the metal of the car. i fixed that with some nail polish quite thickly spread around the protruding cylinder. this covered the minute hole and thus stopped the sparking,
all of these have stopped the problems for now, but dust and dirt do get in the jacket around the distributor so there may not actually be contact between the spindle and the contacts. and that may be all that is wrong with it.
more fun than it seems, MkIII
