Results 1 to 2 of 2
Thread: Has anybody else had this prob?
    GEELONG
    Hi Guys..........
    I have a 1996 mk3 2L auto Golf with only 107ks................
    Prob.........sometimes while waiting for the traffic lights to change (with the foot on the brake), the engine will hesitate/flutter/start to stall/stop/cut out (best way I can descibe the symptom) and then just picks up revs again as though nothing happened.
    The same hesitancy/flutter also occurs sometimes when cruising down the highway at 100ks.
    Anybody have any ideas, answers or solutions??
    cheers.....Doublecab
    Jul 2007
    Rowville Melbourne
    ok my answer is pretty much gonna say the same thing.
    i used to have a 95 2.0 and occasionally while i was driving Peggy Sue (that was her name) would either sputter and sould like she was dying a terrible death or drop revs to 0 and the oil light would come on, then she'd start up again cos i was still in gear and moving, then everything would be fine. she also wouldnt rev past 5000rpm. i started to do some research and figured out it was SOMETHING to do with the crank angle sender or hall sender ( i cant remember if they were the same thing of not.) im talkin about the sensor that sits on the side of the distributor. the problem would go away for a while if i deleted the fault (i have access to a diagnostic computer) to do with the hall sender ( no not the fault that comes up when the ignition is on but engine not running).
    but to be honest i never bothered to get to the bottom of it cos i went with some VR6 goodness wooooooo!
    -steve
