I'll go and vag it now but last time i checked there was no codes...
just changed the fuel filter last week when it started getting bad.
Have you tried doing a VAG COM at all? Maybe it is bringing up some error codes.
what about a coil mine just went and common on these things
Friday, 22 December 2006, 17:54:43
VAG-COM Version: Release 409.1-S
Control Module Part Number: 021 906 258 BK
Component and/or Version: MOTOR PMC 1
Software Coding: 0261203219
Work Shop Code: 1267358109
1 Fault Found:
00537 - Lambda (Oxygen Sensor) Regulation
08-00 -- Control Limit Surpassed
I clear it and it comes straight back.... any ideas? according to what i have read, its an injector issue....
[QUOTE=BlackVr6ix]
get in and try and start. Fails first time, try again fires straight up 90% of the time.
QUOTE]
does it die after starting? or does the starter motor not move at all?
if the former, it could be the key chip not registering with the reader in the ignition - take it out and try again
not sure of the cure if it is the latter problem though...
\'95 Golf VR6
turns over but doesnt fire AT ALL the first time round.
might be a silly question. but are your spark plugs in good condition?
That code is for the lambda sensor in the exhaust which analyses the exhaust gas.
If this is dodgy, it will not read immediately, only after engine has generated more gas. This is why car will not start first time.
Change the sensor and you are in
I do need to change the plugs actually, i am having trouble finding a tool that can get the plug boot off, my plastic one is rooted.
