Results 11 to 20 of 28
Thread: Hard Starting
    Sep 2006
    Australia?
    Have you tried doing a VAG COM at all? Maybe it is bringing up some error codes.
    Aug 2006
    Skye, Victoria
    I'll go and vag it now but last time i checked there was no codes...
    just changed the fuel filter last week when it started getting bad.
    Oct 2006
    sydney
    what about a coil mine just went and common on these things
    Aug 2006
    Skye, Victoria
    Friday, 22 December 2006, 17:54:43
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 021 906 258 BK
    Component and/or Version: MOTOR PMC 1
    Software Coding: 0261203219
    Work Shop Code: 1267358109
    1 Fault Found:
    00537 - Lambda (Oxygen Sensor) Regulation
    08-00 -- Control Limit Surpassed
    Aug 2006
    Skye, Victoria
    I clear it and it comes straight back.... any ideas? according to what i have read, its an injector issue....
    Oct 2005
    [QUOTE=BlackVr6ix]
    get in and try and start. Fails first time, try again fires straight up 90% of the time.
    QUOTE]
    does it die after starting? or does the starter motor not move at all?
    if the former, it could be the key chip not registering with the reader in the ignition - take it out and try again
    not sure of the cure if it is the latter problem though...
    \'95 Golf VR6
    Aug 2006
    Skye, Victoria
    turns over but doesnt fire AT ALL the first time round.
    Point Cook, Vic
    might be a silly question. but are your spark plugs in good condition?
    FOLLOW US ON FACEBOOK
    Camden, Sydney
    That code is for the lambda sensor in the exhaust which analyses the exhaust gas.
    If this is dodgy, it will not read immediately, only after engine has generated more gas. This is why car will not start first time.
    Change the sensor and you are in
    Aug 2006
    Skye, Victoria
    I do need to change the plugs actually, i am having trouble finding a tool that can get the plug boot off, my plastic one is rooted.
Similar Threads
  1. Passat Hard to Start when Hot.
    By auspassat in forum Passat (B4 & B5)
    Last Post: 12-03-2007, 11:13 PM
  2. T4 Starting woes
    By Golf Loon in forum Transporter, Multivan, Caravelle, Kombi
    Last Post: 17-07-2006, 11:16 PM
  3. Starting Trouble... 2.0lt 1995 Mk3
    By golf-kart in forum Mk3 Golf & Vento
    Last Post: 25-04-2006, 06:18 PM
  4. VR6 intermittent cut out on starting - any suggestions?
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 09-01-2006, 11:29 AM
  5. Car hard to start on cold startup
    By Golf Loon in forum Mk2 Golf & Jetta
    Last Post: 08-11-2005, 09:47 PM
