Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Hard gearing - lubrication didn't help
    Aug 2008
    Mid North Coast NSW
    the ball is where the worst will be..............min was that far gone I was able to push some large rubber hose over it to get me through until new part arrived.
    I even had to put qute a few layers of good cloth tape around it to take up the final bit of slack....
    May 2013
    Oslo, Norway
    So, that begs the question: Is the ball supposed to be able to rotate inside its cage? If I put rubber around it, that might take up all the space around it, preventing it from rotating, like it does now.
    Aug 2008
    Mid North Coast NSW
    they need to rotate, or at least slide......there where aftermarket ones available that were square shaped........Fill th gap until there is only just enough "clearance" for it to move......
    Calling NSW Mid North Coast VW Enthusiasts - Click Below
    Mid North Coast Dub Club
    May 2013
    Oslo, Norway
    Here's some better accessible youtube.video:
    From linkage to gearbox
    https://youtu.be/dt9pKrPhyew
    Angular direct by wall
    https://youtu.be/xRsXkRsuF7g
    Front ball
    https://youtu.be/5y06fxVKXz4
    May 2013
    Oslo, Norway
    Well, too late.. I was rolling along three weeks ago, when the stick suddenly got stuck between third and fourth gear and a very telling grinding noise sounded from the front. I was far from home, and had to hand it over to the local wrecker.
