Bug_racer supports the rebellion of the euro revolution
$6000 for a stage 4 i can do all that for cheaper
94' Golf Mk3 Vr6
The hardware is pretty cheap to set up. But.
Decent turbo: 2k
Water & oil lines: $100
Dump pipe: $600~
Full zorst: $500
Exhaust mani: $500
Charge pipe & filter: $100
Inter cooler: $500
4"maf: $100+
Injectors: $250
Boost controller: $$50-$700
Waste gate: $300
Plus if you want to be safe
Drive shop axles: $1500
LSD: $1000
Ecu: mega squirt? $600 plus tuning, Up to 3k.
The only good thing with the kit would do would be the tuning. For me obd1, there is stuff all for the 258bk ecu. Obd2 probably have a better chance.
Bring your car along to ILV if its running.
Im having so much trouble with the car atm . my right hand rear wheel bearing gave up and my brake caliper dug into my rotor . weird noises are coming from my left hand front. found out that my side jacking sills are bent after taking of my side skirts the guy i bought it of jacked the car up from the wrong spotsthis car is being a PAIN IN THE ARSRE .Im not sure if ill have the wheels ready by 10th of march . but i will try my best to attend it. im thinking of reshelling.
94' Golf Mk3 Vr6
