Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: Hakan's VR6 TURBO Build (slow progress)
  1. #21
    Sep 2006
    Quote Originally Posted by Hakan View Post
    ive got bent exhaust valves so I was thinking of oversizing the exhaust valves
    Mate, i got the same idea for my vr6, however i do agree with pete!
    keep standard sized valves as it will draw in the air quicker and faster at lower RPM to help you spool that turbo quicker. if you use oversized valves, you will make more power up top near the 5500-7000, however it will drive a like a dog down low around town. the gtx35 will give you more than enough power to handle at the front tyres. even if you run 245 tyres and LSD u will still slip and carry on.
    my plan for my head is to reshave the head and make it true, run standard size valves and 260s or 270s degree cams with springs and retainers. i will also get it ported BUT NOT POLISH (NEVER POLISH PORTS) thats a myth, when polishing ports, it will actually slow down the airflow and also prevent proper fuel mixture. only port match and smoothen out the valve guides, so there is a small amount of turbulence to allow the fuel to mix with the air efficiency prior entering the combustion chamber.
  2. #22
    Nov 2010
    sunshine,vic
    hmm i never looked at it in that way thats really good to know thanks for the headsup . what about the compression should i go 8:5 cr or 9s ?
    94' Golf Mk3 Vr6
  3. #23
    Sep 2006
    Depends how much boost u want to run, the size ring gaps for ur top and second piston rings and driveability..........8.5 will lose torque downlow over the 9 however it will handle more boost up top. Speak to ur engine builder on their recommendations.....
  4. #24
    Apr 2006
    VW Race HQ - Sydney
    Anything bigger than a gtx3076 its not useable on the street . With a gt35 you must be building a pure drag car or time attack car ?
    Let me know how you go with the balance factor on the crank . Im always keen to hear what other engine builders use .
    Id budget about 30-35k for a build using a base car doing everything properly . Cut corners expect things to break
    Good luck .
    Bug_racer supports the rebellion of the euro revolution
  5. #25
    Sep 2010
    Wheelers Hill
    Quote Originally Posted by Bug_racer View Post
    Good luck .
    Fark 35k for a mk3 vr6
    There's a mk4 r32 turbo selling for 40k I would rather buy that
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
  6. #26
    Sep 2006
    35k is having an APR approach to it, however i do agree u have to have deep pockets to attempt. Ive seen many workshops attempted and then abandon the project either due to lost of interest, short of funds or things arnt going their way...... If ur a true hobbiest, i would spend about 8-10k on parts alone and then 3-4k on head work( dont attempt this unless u know what ur doing and understand the risks) and then 3-4k on tuner time. If u run an autronic ecu with cdi, you should be able to do most of the tuning urself using their auto-tune software, just enough to get the car started.... Then u got dyno time.... So i wouldnt be surpraised if u hit 20k....
  7. #27
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by kinezo View Post
    port matching might be a good idea for any head other than a 12v. never port match a 12v head!
  8. #28
    Feb 2008
    mOOROOLBARK
    Anyone ever heard of a compound turbo set up on a vr6 might be interesting if you want to go big?
  9. #29
    Sep 2006
    Quote Originally Posted by mk3pete View Post
    whats ur theory and case? regarding to the port matching.....?
  10. #30
    Jan 2010
    Melb Westsideeeee
    Damn bro last time i was over the head wasnt even off.. ahaha when did you do all that work? Ill swing past when i can to see the progress haks
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
