Yes it's safe to do so ! Although u might want change your piston rings if your engines around 250kms or higher.
Stock computers take up to 8 or 9psi (carnt remember right now) so doing 7psi would be playin it alittle safer. The guy with the supercharged vr6 ran the stock comp. with i think it was 8psi, it gave up after about a month or 2.
Power's around 240hp. 7psi is pretty gay, reason ? Well I'm pretty sure just about all other turbo cars your gonna attract will beat you and then your gonna get annoyed and go all out![]()
Contact C2 Motorsports an see what they can do for u with a stock computer. obd1 is abit hard to work with.
Pm Malteser on the forums an see if he changed his injectors an pump, carnt remember if u need to.
