Results 11 to 20 of 46
Thread: Hakan's Golf Vr6
Hakan Hakan's Golf Vr6 28-06-2011, 07:51 PM
rayray086 Good to see a VR6 being... 28-06-2011, 08:13 PM
ryana89 Crikey! You don't muck... 28-06-2011, 08:18 PM
GeorgeMK1 Weeeeeeeee haks when are we... 28-06-2011, 08:23 PM
Hakan YEA this is my first and only... 28-06-2011, 08:27 PM
Hakan vr6 msd ignition conversion 28-06-2011, 08:28 PM
Mk3 AAA Did you lose your handle at... 29-06-2011, 11:33 AM
Hakan Nah no upgrades to the head... 29-06-2011, 05:44 PM
KKK VR6 Top stuff !! you ever dynoed... 02-07-2011, 12:43 AM
Hakan Okay finaly I got a reason to... 09-07-2011, 05:53 PM
Water Boy Pics of rebuild are a must... 09-07-2011, 06:04 PM
Hakan Yepp soon soon 09-07-2011, 06:10 PM
valentino Nice!!!!!!! 20-09-2011, 08:41 AM
Hakan Time has come once again 23-09-2011, 11:45 PM
Hakan http://www.vwwatercooled.com.a... 23-09-2011, 11:48 PM
Hakan MORE pictures 23-09-2011, 11:53 PM
dark boo on the no turbo thing!... 24-09-2011, 07:32 AM
Ben J Haha :) didn't see that one... 24-09-2011, 08:24 AM
Hakan Turbooo 24-09-2011, 11:20 PM
KKK VR6 Yes it's safe to do so !... 28-09-2011, 05:34 PM
Hakan okay that sounds alright... 28-09-2011, 06:18 PM
Defaultuser0520 Whats giac stand for? Also... 28-09-2011, 07:10 PM
KKK VR6 Bloody iPhone !! Forged is... 28-09-2011, 07:22 PM
Ben J giac is just an ecu mapping... 28-09-2011, 07:39 PM
Hakan UPDATE!!! 4/10/11 12:07am 03-10-2011, 11:07 PM
Hakan Updated 6-11-11 05-11-2011, 11:14 PM
KKK VR6 Top stuff !! Ultra low =... 07-11-2011, 02:49 PM
Hakan yea just wanted to go... 07-11-2011, 04:12 PM
Ben J Do it. 7.5s up front and 9s... 07-11-2011, 05:23 PM
    Nov 2010
    sunshine,vic
    Okay finaly I got a reason to strip my car and put off the road and start my 1 year rebuild ( I LOST MY LICENSE)
    List off things to do:
    ENGINE:
    Buy a Vr6 Motor from wreckers and strip It.
    Buy PPM Forged pistons (82mm, 8.5.1 Comp) with Forged H beam Con-Rods
    Get the Block Bored out to fit 82mm pistons
    Resurface the block and head and get it sand blasted
    New Crankshaft and bearings+ Billet main caps , oil pump+oil pickup, BBM Turbo Sump,Timing chain Kit.front and rear main seals Etc...
    Schrick 268° 11.4mm Camshafts
    HD Valve springs + Lightweight Lifters + Titanium Valve Spring Retainers+Stainless Steel Valves.
    New BBM lightned flywheel+Exedy HD clutch KIT.
    New o2a Gearbox with Pelequin LsD
    New Driveshafts and new wheel bearings and speed sencors
    T3/T4 turbo Kit (470hp@wheels Rated ) @ 25 psi
    Cant think of anything else right now but will add more soon when I think of more on the engine.
    Suspension System:
    H&R coilovers all round
    H&R Sway Bars
    Poly Utheraine bushes all round
    Front Strut brace (adjustable)
    ------------------------------------------------------------------------------------------------------------------------------------------------------------Exterior :
    Body respray Either Same colour Or Lemans Blue or Jazz Blue Still deciding
    Some decent deepdish rims still looking !!
    ALL OF THIS MIGHT SOUND BULL SHIZ BUT IVE ACTUALLY STARTED THE PROJECT AND THERES NO GOING BACK
    Aug 2006
    Melbourne VIC
    Nov 2010
    sunshine,vic
    Yepp soon soon
    Apr 2011
    Pity you are not in Qld, I have a complete VR6 with an engine that needs rebuilding to get rid of
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    melbourne
    Nice!!!!!!!
    Nov 2010
    sunshine,vic
    okay ladies and gentleman time has come to the day we all were waiting for , ive started the rebuild and ive changed many ideas. today 23/9/2011 5:30pm ive started taking off the engine and gearbox by 7.30pm it was out Ive found that my clutch is still alright after having no 1st gear where i was taking off in 2nd. My rear main seal is leaking again. thrust bearing R.I.P!!! .
    SO THIS TIME My plans are to keep it All original so bad news for some no forced induction
    and keep the car clean and problemless =(less headaches).So all im going to be doing is rebuild my gearbox with stronger gears,
    new HD clutch kit from exedy.
    new drive shafts,new wheel bearings
    ,Polyuruthane bushes all around.new ball joing
    and tie rod ends,new coilovers (still deciding).
    3" super sprint exhaust, schrick 276* cams ,
    schrick HD valve springs,chip tune.new wheels (audi rs4 rims) and tyres.
    And more just cant think of much right now. ill try posting some pictures up
    Nov 2010
    sunshine,vic
    Nov 2010
    sunshine,vic
    MORE pictures
    Dec 2010
    Gold Coast, Queensland
    boo on the no turbo thing! But I understand
    Sep 2009
    Haha didn't see that one coming.
    Nah sorry, good luck with the rebuild.
    For what its worth I hear 268s make like the same power as 276s but don't lose so much low end. Also if your in the gearbox have you considered a 3.94 r&p and a longer 5th gear?
    Sent from my HTC Wildfire using Tapatalk
