Mate what suspension do you have???? i know you have probably mentioned. Sway bar is where i was going to jump. you have had the thing jacked up recently doing all of your work , is your springs seated properly?????? Now we had big problems in the UK with clunks on Mk2 and 3 and it was the insert that goes up through the subrame bush into the chassis. This was a metal insert that used to break away (in the Uk it was mainly from corrosion). Your rear subframe bolt goes up through this insert. When they are stuffed this causes movement in the subframe especailly that reverse clunk you are getting. I will do a bit of research as i cant quite remember if the VRs have this
Jmac
Alba European
