Results 1 to 8 of 8
Thread: Golf VR6 - start up issue, can anyone help?
    Jun 2008
    Hobart, TAS
    When you say it sounds 'dry', do you mean it sounds starved of fuel? Having just done a service I'd be looking at the fuel rail, make sure it's all properly sealed, etc and make sure it's getting enough fuel.
    If ok check lines and pump, as well as throttle body/TPS.
    Sometimes can be painful but the noise of a VR is awesome
    Jun 2013
    Leichhardt, NSW
    Quote Originally Posted by SpeciP3 View Post
    I have to agree, Im running a Remus Exhaust, suit case removed, air box has been modifed to allow more air, etc.. Sound a $1mil under throttle.
    When I say dry, amost as if no oil, however I dont think this is the case. When turning ignition on, fuel pump starts and you can hear it huming away so I dont think that is the issue either.
    I have gone from a 0w50 to a 10w 50 so I woinder if this could have anything to do with it? Ive also added Lucas Addtive which is phenominal. Ive never had a naissue with Lucas in the past so doubt that this would be the issue also..
