Hi all.
Came across this and thought it may be of use so I posted it. By chance, can anyone elaborate and actually state what the actual relay numbers are? example 36, 188, 91, etc...
Figure this could be used in the future and be a great help when fixingout electrical issues.
FUSE ARRANGEMENT INCL AMP
1. Headlight, low beam left........10
2. Headlight, low beam right......10
3. Instrument panel lights, licence plate lights......10
4. Rear window wiper.......15
5. Wiper / washer front......15
6. Fresh air fan.....20
7. Tail light/ side marker light right.....10
8. Tail light /side marker light left......10
9. Rear window defogger.....20
10. Fog lights.....15
11. Headlight, high beam left......10
12. Headlight, high beam right.....10
13. Horn, radiator fan run on.....10
14. Back up lights, washer jet heaters.....10
15. Electronic Ignition, idle stabilizer, deceleration fuel shut off.....10
16. Dash warning lights, glove box light, cassette storage, rear spoiler adjustment control unit......15
17. Emergency flasher switch, turn signal...10
18. Fuel pump.....20
19. Radiator coolant fan A/C......30
20. Brake lights.....10
21. Interior lights, cigarette lighter, digital clock, rear spolier adjustment.....15
22. Radio.....10
RELAY LOCATION ON FUSE RELAY PANEL (both 2 rows above fuses with #1 starting on 2nd row working left to right)
1. A/C. relay
2. Rear window wiper relay
3. Digitant control unit
4. Load reduction relay
5. Low coolant level
6. Emergency flasher relay
7 - Open
8. Intermittent wiper relay
9. Seat belt warning system
10. Fog light relay
11. Horn relay
12. Fuel pump relay
SEPERATE RELAYS ABOVE FUSE/RELAY PANEL (13 starts bottom row left to right and 19 top row left to right)
13. ABShydraulic pump relay
14. ABS relay
15. Radiator fan after run relay
16. Fuel pump after run control unit
17. Heated seat relay driver
18. Heated seat relay passanger
19. Open
20. Open
21. ABS hydraulic pump fuse, power window fuse
22. ABS valves fuse
23. Open
24. Open
