Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Going Limp
    This might be a duff lambda probe or one that is slow to warm up. Not easy to diagnose if it is. Swapping in a new one might prove it or monitoring the output voltage with a scope. You would need to check it from stone cold.
    Nov 2007
    Williamstown, Vic
    Mine is a late '93 build. I find too that at just over 3,000 revs when oil temp is below 50 degrees, even with light throttle, the engine cuts back and the car stutters along. If I restart the car it resets and clears the problem, but I can hardly do that moving in traffic.
    If it is supposed to be a feature of the car to stop it being thrashed when cold, it is silly as it can be quite dangerous in an emergency situation.
    So, just wondering if there is a fuse or some other quirky VW fitment that I can remove to stop it doing this.
    Quote Originally Posted by DavoVR6 View Post
    Not a feature, it's a fault IMO. I'd have the ECU scanned for faults first.
    Aug 2007
    THe early ones did have a cut back in the ecu, this one sounds a bit more fierce but only recently had an early one here and i revved it cold and it ran like a turd, anyway with refeerence to the lambda probe you are in open loop cold.
    JMAc
    Alba European
    Quote Originally Posted by Jmac View Post
    JMAc
    Good point about the open loop.
    Sep 2006
    Parkinson / Brisbane
    too weird
