i have the same problem, i haven't figured it out but it could be related to the MAF/Fuel Pressure Regulator/IAC and throttle - need a VAGCOM to test the codes.....
OR the Vacuum system for the fuel, which may include the fuel pump - if the cruise control or recycle button for air vents doesn't work it might be this....(i.e. the vacuum pump or vacuum line problem..
If you've played around with the Thottle dashpot, the pedal cluster or throttle contol valve apparently the computer will pick this up and revert to a basic mode.
I hope i got that right, as thats my understanding of it...and it is limited
